2008 Yamaha 450 grizzly won't change gears
Anyone have any input my bike won't change gears I disconnected the shifter linkage and a can turn gear and shows all the light lighting low high neutral reverse park but stays in forward or wants to try and move forward in every gear. What can I do next any idea?
when running and just with Key off it shows lights changing gears. I removed the linkage and used pliers thinking maybe linkage but same issue. I opened the hub the linkage is attached to and put socket on bolt and changed gears same thing shows light changing but still in drive. even went as far as pulling the secondary thinking something in there but looks ok. So now I'm not sure what next step is
I always forget about the foot brake. I'll have to use that next time I ride, probably will be easier than the hand lever when shifting. To me, the Yamahas with the shifter on the left side always seems a bit awkward. I wish they put it on the right like Kawasaki, Can-Am and Polaris. I still find myself using my right hand to shift even though it should be easier with the left.
