Transfer case oil problem
I have a 95 kodiak 400 4x4, I am servicing it. I took the cap off the transfer case and oil came running out. I quickly put the cap back on.
Is the motor oil and transfer case oil separate?
Other than the previous owner over filling what else would cause this?
Does the transfer case use the same oil as the engine? atv oil
thanks for the help
thanks for the help
thanks for the help
thanks for the help
^^^ Ok, I haven't actually seen an air cooled Kodiak, must have been when they first came out and maybe not that many of them around. How about a pic of the machine.
I am pointing at the plug I took out and oil came rushing out of.[/QUOTE]
Got me there....I believe it may in fact have a transfer case.. I have never seen nor worked on one of those but I believe it to be very similar to the Big Bear, which I have worked on but only the fuel system. Hopefully someone else will jump in here and provide you some direction, I can't....sorry.
I don't know what it uses.... Have you tried to Google it....or get a manual. Here's a link for a manual and the download is usually $5.....Will pay for itself in just a few minutes.
https://www.tradebit.com/G/manuals/188-yamaha
