Help with 01 Yamaha warrior 350
Hey everyone, I'm new to the forum... First off I want to say that I have searched the web high and low and can't find an answer... So here's what's going on.
I got a 01 Yamaha warrior on a trade, it didn't run, has a bad stator so I fixed it and got it running ran pretty good and had a lot of power and started right up, but there was a ticking like the valves needed to be adjusted so I adjusted the valves and still made a ticking noise... So I looked at the timing and at top dead center noticed that the cam was flipped at 180 degrees. So I flipped it and got all the timing marks aligned and reset the valves. Put everything together and had a hard time starting it but it eventually fired up and sounded great no more ticking and sounded real healthy. So I shut it down and now it has a very very hard time starting get it going for a quick second and then stops and doesn't want to start....
I don't know what to do now or what to check for. Any help would be greatly appreciated
Something else may be wrong...another problem. Have you checked the plug when it won't start....wet, dry, and what about the spark.....constant...blueish in color?
