1998 Yamaha Blaster
if your picture shows near the back right of the air box, that is where you put the oil into the oil tank. Now if you are not using the oil pump which I assume and just mixing your oil an gas, then you should just throw the oil tank under your seat away. That is very common as not many people use the oil delivery system in their blasters as it is known to not work properly as blasters go through a lot of abuse and rpm changes frequently.
My friend who I am always helping him work on a blaster goes further and takes the plastic gear out of the oil pump in the engine too.
zdrucker
08-17-2016 05:13 PM
