2006 Arctic Cat Prowler XT – A
undefined
Arctic Cat ATVs have always had More To Go On. More ground clearance for tackling the harshest obstacles, More rack accessory ingenuity for farming, hunting and fishing, and when it comes down to spending seat time on an Arctic Cat, they are More fun.
The Prowler XT is a new category entrant by Arctic Cat in the UTV market. This highly agile utility machine is chock full of all the rugged functionality found on an Arctic Cat ATV, but packaged in a chassis scaled for power, maneuverability and ease of driving.
The cab of the Prowler XT is equipped with dual bucket seats and driver/passenger seat belts, a center console complete with drink holders and dual 12v accessory plugs. The open air cab has a full canopy and various storage compartments like a dash mounted tray shelf, glove box with door and an easily accessible molded tool kit located under the passenger-side seat.
Keeping true to Arctic Cat ATV heritage, the Prowler XT was designed to conquer any job when it comes to storage and hauling capacities. Lift the hood on any Prowler and you will find a storage compartment that can hold 25lbs of hunting supplies or tools, and can double as a cooler to store ice. The composite cargo bed resists rust and cracking so you can throw in 600lbs. of the harshest payloads and the Prowler won’t even whimper.
Hardcore jobs and hardcore fun are only executed when provided with a hardcore engine, drivetrain and suspension system. Born and bred at Arctic Cat, this 641cc, 4-stroke, single-cylinder torque monster motor will supply more than enough power. The CVT transmission with Low, High, Neutral and Reverse is as easy to use as an Arctic Cat ATV; just gas it and go.
Arctic Cat engineers have laid to rest the claims of “best” suspension travel and ground clearance by other manufacturers. The front and rear suspensions are Fully Independent with a double A-arm front design and a double a-arm rear design with 10” of suspension travel for sure footed offroad prowess. Spring preload adjustable shocks are used on all four corners for the ultimate in terrain and load adjustability, while off-roading capabilities are enhanced by 12.5” of ground clearance, a front locking 4wd differential and rear mounted swaybar for improved trail driving. Cast aluminum 14” wheels with color-matched inserts are standard with 26×9-14 Goodyear MTR front tires and 26×11-14 Goodyear MTRs in the rear for the ultimate in offroad traction.
Once again, Arctic Cat provides a new category entrant that holds true to the More to Go On slogan. The Prowler XT provides More comfort, More useable horsepower and More cargo storage. Don’t get too comfortable at home reading all the new specifications; somebody is buying your new Prowler XT at the dealership right now!
Features
  • 641cc, 4-stroke, single-cylinder, liquid cooled engine
  • An Arctic Cat produced engine in their state-of-the-art manufacturing facility
  • 36mm Keihin carburetors with automatic choke
  • Liquid cooling system with high-capacity radiator and thermostatically-controlled cooling fan provides consistent engine operating temperatures
  • Duramatic Automatic Transmission with long life maintenance-free belt
    Prowler XT 650 Key Features:
  • Fully Independent Suspension
  • Adjustable spring preload shocks
  • 12.5” ground clearance
  • 10” of front and rear suspension travel
  • Standard digital gauges w/red backlighting
Specifications
  • Engine: SOHC 4-stroke 4-valve
  • Displacement: 641
  • Bore x stroke: 98×85
  • Compression ratio:
  • Carburetion:
  • Ignition:
  • Transmission: Automatic CVT with EBS
  • Final drive:
  • Frame:
  • Suspension front / wheel travel: Double A-Arm/10.00
  • Suspension rear / wheel travel:  Double A-Arm/10.00
  • Front tire: 26×9-14
  • Rear tire: 26×11-14
  • Front brakes / rear brake:
  • Overall length: 115.0
  • Overall width: 61.3
  • Wheelbase: 75.0
  • Ground clearance: 12.50
  • Seat height:
  • Lighting:
  • Rack capacity, front / rear:
  • Towing capacity:
  • Fuel capacity: 8/ 30.3 L
  • Dry weight:
  • Instruments:
  • Color choices:
  • MSRP:
