2006 Arctic Cat Youth ATV
2006 Arctic Cat Youth ATV’s
undefined
Cat Family styling and fun doesn’t end with Arctic Cat’s full size ATV’s. The same quality features and benefits that define an Arctic ATV are also found in the new 50cc and 90cc four-stroke DVX and 2×4 Youth platforms.
Both machines are outfi tted with a multitude of safety features, including full fl oorboards, padded handlebars, removable keys, standard rear brake lights, and a highly visible orange whip safety flag.
Built for riders ages 6 and older, both 50 models have a New 50cc four-stroke engine with reliable performance that eliminates the hassle of mixing gas and oil typically associated with 2-stroke machines. The Duramatic automatic transmission means no shifting for the rider, and a standard throttle governor keeps speed at 10mph.
Both 90 models are designed for riders 12 and older, and are powered by a 90cc four-stroke engine with Duramatic automatic transmission and a 15mph speed governor.
Automatic choke is standard on both machines, making starting simple and quick. Hand operated front and rear brakes keep both machines in control, as do the independent front and rear swingarm suspensions. New for 2006, both machines get an updated Cat Family look with your choice of DVXor Utility-type bodywork. Put a smile on your Youth’s face today; Arctic Cat gives them More to Go On.
50/90 Engline Features:
  • 50cc or 90cc, Air-cooled, Single Overhead
  • Cam, 2-valve, 4-stroke engines
  • Automatic CVT transmissions
  • Electric start with automatic choke and
    kick-start backup
  • Removable throttle/speed limiting
    governor
50/90 Youth- and Parent- Friendly Features:
  • Clean, quiet, reliable 50cc 4-stroke model
    developed especially for riders 6yrs old
    and up
  • Clean, quiet, reliable 90cc 4-stroke model
    developed especially for riders 12yrs and
    older
  • Bright orange whip fl ags included for
    visibility and increased safety
  • Utility- or Sport-look body styling so youth
    can look like Mom or Dad’s full size Arctic
    Cat ATV
  • Standard brake light for added safety
    when being followed
  • Parent controlled throttle/speed limiters so
    adults can adjust speed outputs to youth’s
    skill level
Specifications
  • Engine: SOHC 4-stroke 2-valve
  • Displacement: 89.9
  • Bore x stroke: 47×51.8
  • Compression ratio:
  • Carburetion:
  • Ignition:
  • Transmission: Automatic CVT
  • Final drive: 2 WD
  • Frame:
  • Suspension front / wheel travel: Single A-Arm / 2.8” (71 mm)
  • Suspension rear / wheel travel: MONO / 2.9” (74 mm)
  • Front tire: 19×8-8
  • Rear tire: 20×7-8
  • Front brakes / rear brake:
  • Overall length: 57.8
  • Overall width: 34.5
  • Wheelbase: 38.4
  • Ground clearance: 7.25″ center 4.75″ rear
  • Seat height:
  • Lighting:
  • Rack capacity, front / rear:
  • Towing capacity:
  • Fuel capacity:
  • Dry weight:
  • Instruments:
  • Color choices:
  • MSRP:
