Bush Hog TH4400 Front CV Axles
Old 02-23-2024 | 08:21 PM
0418brennan's Avatar
Default Bush Hog TH4400 Front CV Axles
Anyone know which front axles fit these?
part number? I’m completely lost!
06 Sportman fit the rear.
axles measure 24 1/4?
thank you.
Old 03-02-2024 | 08:53 PM
Axle Part Number: CAS305F2B.018. East Lake axle makes them.
fronts you need to use axle above and take it apart and put the new inner and outer on your old axle.
this same axle fits the rear.
Intella Parts makes the front brake calipers still brand new. They call them brake bodies.
https://intellaparts.com/p/BH-500622...h-Bushing.html
these struts you can use on the front of the machine. I installed them. Worked fine.
405673. Find the pair on Amazon. I’ll be adding to this as I continue to find parts.
Old Yesterday | 08:40 AM
DOM3's Avatar
Did you find any other information?
I have an 06 Bush Hog TH4400 its missing the drivers rear CV. I figured I would replace all four however the teeth count are different from the 2006 Bush Hog to the Polaris 500...... Help
badmoose
Polaris Side by Sides
12-11-2007 10:26 PM
stewartlittle
05-07-2007 07:17 AM
polarisbear500
04-19-2005 10:28 PM
Quick Reply: Bush Hog TH4400 Front CV Axles
