2006 TRX 90 No Spark
I need a little diagnosis help. Picked this machine up not running. The stator cover was removed and it was weather beaten from sitting for 2 years. I cleaned the carb, put a fresh battery in it and reinstalled the stator...no spark. Cleaned the switches tested the stator and ohmed the coil. The coil tested bad turned out the wire was broken inside. New coil...no spark. I couldn't find good info on testing the stator for this machine. In the past I have ohm tested the stators on other machines but online chatter says voltage test this one. I did ohm test it first and on the Bl/W wire and Y/W which I believe are the CDI trigger wires I got 120ohms. When I voltage tested it I got 5.5 volts AC on the white wire (charge circuit) and .5 volts AC on the two trigger wires. That seemed very low so I ordered a new stator and it read absolutely identical on the ohms and volts when tested...no spark. Any ideas what to test or how to test?
AZScrambled
11-27-2010 07:34 PM
