2007 Kawasaki KFX 700 Sport ATV
Popular V-twin sport model offers multiple uses
![undefined](/Features/Buyers_Guide/Kawasaki/images/dune700s.jpg)
The KFX®700 all-terrain vehicle (ATV) continues to be popular with off-roaders. That’s because Kawasaki bolted a powerful V-twin engine and automatic transmission
into its racing-style chassis, making aggressive riding on the KFX700 fun and easy, from morning to sunset.
And for 2007, the KFX700 comes in a cool Meteor Blue or stunning Black Marble, in addition to Kawasaki’s trademark Lime Green.
The KFX700’s power and performance begins with its engine. The liquid-cooled, 697cc, four-stroke, 90-degree V-twin is matched to a performance-tuned continuously variable automatic transmission. Combined, the powerful engine and automatic transmission eliminate rpm and shifting concerns because it’s in the optimum powerband at all times. This allows the rider to focus even more attention on choosing good lines, whether it’s on the race track or trail.
Other features include shaft drive, powerful dual front disc brakes and Kawasaki’s sealed, oil-bathed, multi-disc rear brake system. The KFX700 also features the industry’s first mass-produced ATV chassis with a racing-inspired single lower front frame tube – the design preferred by cross-country ATV racers.
Rear suspension duties are handled by a motocross-inspired swingarm with a piggy-back reservoir shock, and ITP® ® Holeshot tires provide the KFX700 with maximum traction and maneuverability.
Rounding out the features list are sport-style serrated footpegs, a protective engine skid plate and a powerful 45-watt headlight.
Authentic Kawasaki Accessories are available through Kawasaki dealers or they can be purchased on the Internet at www.kawasaki.com.
As with all off-highway vehicle recreation, Kawasaki encourages ATV riders to ride responsibly and to respect the environment. Kawasaki will pay first-time buyers of a new Kawasaki ATV 0 for completing an ATV rider safety course conducted by the ATV Safety Institute (ASI). Interested consumers can call ASI toll-free at 800-887-2887.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft and utility vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in power products and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
™ Kawasaki’s tagline, “Let the good times roll. ”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
- 697cc V-twin engine with dual Keihin downdraft carburetors provide maximum torque while 90-degree cylinder offset produces perfect primary balance to minimize vibration
- Super-responsive Kawasaki continuously variable transmission with special Kevlar reinforced drive belt enhances acceleration while maximizing durability
- Forward-neutral-reverse grip-type shifter is positioned conveniently on the left handlebar to make gear selection quick and easy
- Racing-style chassis with single-spar front frame tube for maximum A-arm length is the design of choice amongst Grand National Cross Country ATV racers
- Dual A-arm front suspension features 9.3 inches of travel—the long, flat angle of the A-arms provide optimum handling by minimizing “tire scrub” during up-and-down suspension travel
- Unitized alloy swingarm with large-capacity, piggyback reservoir shock and dual-rate spring features compression damping, pre-load adjustment and 7.9 inches of travel
- Unitized swingarm also features integrated shaft drive and Kawasaki’s sealed multi-disc brake assembly for superior ground clearance and fade-free braking power
- Low-mounted 3.2-gallon fuel tank helps keep the center of gravity low for enhanced handling
- GNCC-proven ITP® ® Holeshot tires provide maximum traction and stability
- Aluminum alloy rims feature welded inserts for added strength and durability
- 90 watts of halogen lighting power gives the nighttime rider exceptional visibility
- Sport-style serrated footpegs allow maximum rider mobility and control
- Engine:Liquid-cooled, four-stroke V-twin, SOHC, four valves per cylinder with wet sump lubrication
- Displacement:697cc
- Bore x stroke:82 x 66mm
- Compression ratio:
- Carburetion:Dual Keihin CVKR-D32
- Ignition:Electric
- Transmission:Continuously variable transmission with forward, reverse and neutral
- Final drive:Shaft
- Frame:Double cradle, racing type, high-tensile tubular steel
- Suspension front / wheel travel:Dual A-arms, coil-over shocks / 9.3 in.
- Suspension rear / wheel travel:Linkless swingarm, piggy-back reservoir shock, dual-rate spring / 7.9 in.
- Front tire:ITP Holeshot AT22x7-10
- Rear tire:ITP Holeshot AT22x11-10
- Front brakes / rear brake:Dual discs with two-piston calipers/ Sealed, oil-bathed, multi-disc
- Overall length:78.1 in.
- Overall width:47.0 in.
- Wheelbase:50.6 in.
- Ground clearance:At center of chassis – 9.6 in, at rear axle – 6.3 in.
- Seat height:33.5 in.
- Lighting:Dual 45W halogen headlights, 5/21W taillight/brake light
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity:3.2 gal.
- Dry weight:516 lbs.
- Instruments:
- Color choices:Lime Green, Meteor Blue, or Black Marble
- MSRP:TBD
