AMSOIL Adds New 10W-30 and 5W-40 to Synthetic ATV Oil
Two new synthetics formulated for our machines.
AMSOIL is launching two new synthetic lubricants for ATV/UTV applications, providing riders with high-performance upgrades from OEM-branded oils. AMSOIL Synthetic ATV/UTV Motor Oil is now available in 10W-30 and 5W-40 viscosities, joining existing 10W-40 and 5W-50 viscosities to round out the product line.
AMSOIL Synthetic ATV/UTV Motor Oil is designed to withstand the severe operating conditions found in modern ATV/UTV applications. It provides outstanding protection while racing, hauling, plowing or navigating tough terrain. Thanks to its robust all-season synthetic formula, AMSOIL ATV/UTV Oil remains fluid in sub-zero temperatures for exceptional protection during cold starts, and resists thinning and mechanical shear in extreme heat to protect ATV/UTV engines in hard-working or desert conditions.
AMSOIL Synthetic ATV/UTV Motor Oil helps fight rust and corrosion to prolong equipment life. It is wet-clutch compatible, and it’s formulated without friction modifiers to promote smooth shifting and positive clutch engagement, allowing riders to confidently and safely push their machines to the limit.
“We designed the ATV/UTV family of lubricants from the ground up to address the unique demands of these off-road machines,” said AMSOIL Sr. Market Manager – Powersports, Len Groom. “Whether they’re used for work or play, ATVs and UTVs are frequently pushed to the limit, generating high heat that can challenge lubricants’ ability to maintain adequate protection. AMSOIL Synthetic ATV/UTV Motor Oil is designed to protect against the damaging effects of extreme heat, and we’re excited to expand the line to offer upgraded AMSOIL protection to more ATV/UTV makes and models.”
AMSOIL 10W-30 Synthetic ATV/UTV Motor Oil is recommended for use in applications that require a 10W-30 oil, including those made by Honda. AMSOIL 5W-40 Synthetic ATV/UTV Motor Oil is recommended for use in applications that require a 5W-40 oil, including those made by Can-Am and Kawasaki.
AMSOIL Synthetic ATV/UTV Motor Oil is Warranty Secure and will not void ATV or UTV warranties.
More information can be found here.
