Ask The Editors: Brighter Bulbs for my Zook
Also are there any led or better bulbs to use instead of stock replacement?
I am only planning mild trail riding and some light work on my farm for the Quadrunner but extra or better lighting would be a huge benefit for my use.
Pictures of how it would look with said upgrades or changed lighting too that would be greatly appreciated.
Good news – there are indeed 80W Super White LED bulbs available for your Quadrunner that will increase the lighting output to near-ridiculous levels.
No need to bother with pictures of the modification as you will not be interfering with the stock headlight assembly in the least. Rather you will swapping out the bulb for an LED within. And a additional tip would be to soak and clean the headlight lens while performing this upgrade so that more of the light can escape the assembly to reach the trails ahead. Check the automotive section of your preferred retailer to get a quality lens restore kit.
Here is a direct link to the type of LED bulbs you are going to want to pick up. The only downside is they are a bit pricier than the OEM or equivalent bulbs – this case $27.95 for a pair.
