CFMOTO Slams Into The 1000cc SxS Class With New ZFORCE Z10
You have to go big to make it in this class. CFMOTO clearly understands.
If you want to be taken seriously in the premiere 1000cc performance SxS class in 2024, you need some pretty impressive specs. The competition is fierce in this segment. CFMOTO is the latest manufacturer to throw its hat into the ring with their ZFORCE Z10 line, which looks to clearly understand the assignment.
CFMOTO’s all-new ZFORCE Z10 (2 seater) and Z10-4 (4-seater) will feature a brand-new 143 HP triple-cylinder turbocharged engine good for 100 lb-ft of torque and a transmission capable of 2WD, 4WD and differential lock. Perhaps most impressive of all, the price: ZFORCE Z10 – $19,999 and ZFORCE Z10-4 – $22,999.
Here is the complete spec sheet:
Engine: 998cc turbocharged triple-cylinder
Horsepower: 143 @ 7750 RPM
Torque: 100 lb-ft @ 7000 RPM
Fuel System: Bosch EFI
Electronic Throttle with 3 Ride Modes(Comfort/Trail/Sport
Redesigned OmniDive CVT is said to be more efficient and has longer belt life
Display: 12.3-inch RideSync MMI touchscreen display with navigation. Apple CarPlay, and backup camera; additional 7-inch LCD instrument panel
FOX QS3 piggyback 2.5-inch with Eibach Springs have on-the-fly adjustment via electronic steering wheel control switch for SOFT, MEDIUM, FIRM settings.
Wheel travel: 17″ front / 20″ rear
64-inch wide stance
Muli-function steering wheel gets push-button start and more
Electronic Power Steering with 4 Modes (Auto/Low/Mid/High)
4500 lb. Winch with Synthetic Rope is standard equipment
LED Headlights/Taillights/Backup Lights
Half doors
HDPE Skid Plate and Aluminum Bash Plate
14″ Aluminum Wheels with 30″ Tires
Selectable 2WD/4WD/4WD locked drive
LxWxH: Z10 129″ x 64″ x 68.5″ / Z10-4 159″ x 64″ x 68.5″
Wheelbase: Z10 99″ / Z10-4 129″
Dry Weight: Z10 1863 lbs. / z10-4 2105 lbs.
14 inches of ground clearance
9.9 gallon fuel capacity
Independent Suspension F/R…High clearance A-arm/Trailing Arm
14-inch aluminum wheels
CST Pulse XT tires 30x10x14 (same size allows rotation and full size spare)
2 color choices – Nebula Black, Lava Orange
Bus bar for easy electronic accessory install
Front and rear recovery hooks
More information on the ZFORCE Z10 can be found by clicking here.
More information on the ZFORCE Z10-4 can be found by clicking here.
