CTEK Cig Socket Brings Power to Powersports
Clip_3
To the purist, off-roading represents a much needed and deserved break from the gadgets, electronics and connectivity that has become modern life. We dig that. However, there’s no debating the fact that cell phones and similar such devices have made things a lot safer for all involved! Apps like GPS, personal tracking and even the ability to simply call for help in the event of a crash or mechanical failure have changed the game for the better.
The benefits of having a phone with you during an extended ride or camping adventure isn’t always possible when using powersports vehicles. The problem can be the inability to charge your smartphone, navigation unit, or to power auxiliary equipment (from lighting to an iPod to bump them beats). Fortunately, CTEK, a leading innovator and provider of smart Battery Chargers and Maintainers, has a very simple solution.
Clip_1
The CTEK Comfort Connect Cig-socket accessory (part # 56-573) gives powersports users the ability to charge a device while on the move. The Comfort Connect Cig-socket allows conventional “car charger” cables and USB converters to be plugged in to power your personal device.
So what you say, your fancy new side-by-side already came equipped with power ports? The beauty of the CTEK Comfort Connect Cig-socket accessory can be connected via eyelets or clamps to the battery using a separate male connector cable (such as the one provided standard with all CTEK chargers). This waterproof, one-way connector also permits quick connection to a CTEK Battery Charger when the vehicle is not in use, ensuring proper battery maintenance. The CTEK Comfort Connect Cig-socket accessory can be left attached to the vehicle when the charger is not in use.
With a fused lead for safety, and premium design utilizing copper wiring, the CTEK Comfort Connect Cig-socket is the perfect charging accessory for powersports users to ensure your devices are never left without a charge.
Clip_2
To learn more about the complete line of CTEK Battery Chargers and accessories, or to find a CTEK authorized distributor near you, please visit: www.ctek.com
Always check alternator capacity to support device charging before using this accessory on your powersports vehicle.
ABOUT CTEK
CTEK SWEDEN AB develops and manufactures battery chargers and maintainers for all types of lead-acid and lithium batteries for both private and professional use. CTEK’s unparalleled innovation has enabled it to develop cutting edge technology with several patented functions and properties that make CTEK Battery Chargers and accessories unique.
For more information, please visit http://smartercharger.com
