Goodyear Rawhide Camo ATV Tire
June 29th 2006
 By: Press release
Goodyear is pleased to introduce the Goodyear Rawhide Camo ATV replacement tire, the first of its kind in the recreational and utility markets. For the ATV outdoor enthusiast who seeks go-anywhere capability and stealth, there is simply no better choice.
The Rawhide Camo utilizes six-ply bias-type construction that is optimized for durability and riding comfort. A specially designed open-block tread pattern performs especially well in sloppy conditions. The three-quarter inch deep, self-cleaning tread blocks provide the rider with added confidence when the mud gets deeper while maintaining excellent traction in challenging terrain.
The icing on the cake of the Goodyear Rawhide Camo is also an industry first: a durable four-color camouflage pattern molded into the sidewall and tread. To produce the Camo’s pattern, Goodyear’s engineers developed a proprietary process that molds a three-color paint veneer into the tire during the curing stage. Once the tire has cooled, the appearance is dramatic. Together with the natural black of the rubber compound, the resulting four-color pattern blends subtly into natural backgrounds. In the development stage, the Camo was thoroughly tested by Goodyear’s engineers for normal wear, endurance, abrasion toughness and resistance to UV-light fade. The final product is amazingly durable.
undefined
Under normal riding conditions, the high areas of the tread will wear down over time to the black rubber, yet the sidewall–which is most visible in profile–remain essentially unchanged. Which makes the Camo the perfect complement to the growing number of camouflage body designs offered by the leading ATV manufacturers.
The Goodyear Rawhide Camo is available at Goodyear retailers. Initially, the most common sizes for the recreational ATV and utility side-by-side markets will be offered: AT25-8-12 (front) and AT25-10-12 (rear). The following sizes, including the popular 14-inch wheel, will be announced at a later time.
Front: AT26x8R12
26x9R14NHS
Rear: AT26x11R12
26x11R14NHS
