Polaris 2020 Holiday Gift Guide Arrives
The holidays creep up fast every year, and 2020 is no different…except that it’s completely different. With so many things occupying the mind, gift ideas are more appreciated than ever.
Polaris Winch System
$549.99
The incredible pulling power of the Polaris PRO HD 3,500 lb. winch just got a whole lot faster thanks to new Rapid Rope Recovery – a new technology that allows you to retrieve excess cable 5-times faster.
• 3,500 lbs. of pulling capacity
• New Rapid Rope Recovery design with standard pulling mode and high-speed recovery
• Wireless remote control with a 50’ range and a unique code for no interference operation
• Auto Stop Technology stops the winch at completion
• Recover open cable 5-times faster than standard speed
• 1.6-hp motor provides 3,500 lb. rated pulling power
Polaris Men’s Work Jacket
$159.99
This rugged but lightweight work jacket is perfect for riding on a brisk day. The 100% nylon shell is coated with durable water repellency and allows for protection from the elements. 80-gram 3M Thinsulate Insulation adds extra warmth for colder days. You will stay comfortable and agile during your ride with the integrated stretch action back. This jacket layers nicely under your outer shell in the toughest winter conditions.
Polaris Outlaw 70 EFI
Starting at $2299
Parents will appreciate that this machine grows with the rider by featuring an upgraded 70cc engine, a new ergonomic design that is specifically sized for a wider age range (6-10 year olds), and parent-adjustable speed control, enabling youth riders to enjoy it longer.
• Adjustable Speed Limiter
• Single-Lever Disc Brakes
• LED Lights
• Electronic Fuel Injection (EFI)
• 4″ Front/Rear Suspension Travel
Polaris Northstar 30qt. Cooler
$239.99
• Holds Ice 30+ Hours Longer Than YETI
• IGBC Certified Bear-Resistant
• Travel Lock System: Integrated tie-down cleats easily secure to any off-road vehicle, boat or truck
• Ice Lock Seal: Airtight gasket along the lid keeps cold air in
• Polar Wall Insulation: Thick 2-inch insulation ensure premium cooling
• Easy Out Drain System: Large, easy to open plug for rapid draining
• Comfort Carry Handles: Carry a fully loaded cooler with comfort and ease
• NoSlip Rubber Feet: Firm placement on any surface
Polaris RANGER Glacier Plow System
Price varies
Move some serious snow while you remain comfortable in your RANGER. Build your own customized plow system using the Polaris step-by-step Plow System Builder
Polaris Power Portable Inverter Generator
$1599.99
Quiet, efficient, clean power with an electric start and an extended run time for a variety of uses. How’s that for convenient?
• Rated AC Output: 2800W / Max. AC Output: 3200W
• Displacement: 208cc
• Starting System: Recoil & Electric Starter
• (3) AC Receptacles / (2) USB / (1) DC Receptacle
• Fuel Tank Capacity: 1.9 gal
• Run Time @ 25% Load: 10.1 hrs & @ 100% Load: 3.9 hrs
• Dimensions (L x W x H) 25.2″ x 19.3″ x 19.7”
• Dry Weight: 95 lbs
• Fuel Type: US 87 Unleaded Gasoline
Polaris Ranger 150 EFI
Starting at $5499
At 150cc of power, 8” of ground clearance and 50lb of storage capacity, the RANGER 150 EFI is ready for a full day of safe thrill rides for the kids.
• Powered by Ride Command Geofencing Capabilities & Digital Speed Limiting
• Adjustable Steering Wheel & Driver’s Seat
• Passcode Protected Safe Start
• Safety comes standard with safety flag and two helmets
Polaris Northstar Soft Sided 20 qt. Cooler
$159.99
Bring this lightweight Soft Sided Cooler on road trips, to sporting events, camping, or on a weekend with the family. Features a convenient shoulder strap and zipper top.
• Great for road trips, sporting events, camping, or a weekend with the family
• Convenient shoulder strap and zipper top
Polaris Men’s Softshell Jacket
$129.99
• Lightweight softshell jacket lined with 280g of soft fleece for warmth
• Men’s fleece-lined jacket keeps you cozy
• Adjustable hem and wrist gaiters help keep cold air out
• Pit vents let heat and moisture escape
• Water-repellent finish prevents precipitation from saturating jacket’s exterior
• Fits true to size for comfy wear
Polaris Sportsman 450 H.O.
Starting at $6399
The industry’s best value ATV just got better. The new 450 HO is smoother, stronger and more versatile, making your hard-earned dollar go further
• 9.5″ Rear Suspension Travel
• 1,350-lb Towing Capacity
• Factory-Installed Hitch Receiver
• Front Rack Extender
• 485-lb Payload Capacity
• Pre-Wired Handlebar for Hand/Thumb Warmers and Winch
• Factory-Installed Winch and Plow mount plates
