sPOD Mini 6 Steering Wheel Kit for RZR
sPOD Mini 6 Wheel Kit for Polaris RZR Pro R
Power at your fingertips.
sPOD, the leader in dedicated power distribution switch systems, announces the availability of direct integration for the Polaris RZR Pro XP, Turbo R, and Pro R models with the all-new sPOD SourceLT Mini 6 Steering Wheel Kit. Designed to enhance your driving experience while out on the trails, this innovative product by pod brings unmatched convenience and control right to your fingertips.
Mounted directly to the steering wheel for a seamless fit and finish, the sPOD SourceLT Mini 6 Steering Wheel Kit sets a new standard for integration on the Polaris RZR. Gone are the days of fumbling for switches while navigating challenging terrain. With this sPOD power control system, you can effortlessly control up to 6 accessories, each rated at 30 amps per circuit, for a total power management capacity of 100 amps.
Imagine the freedom of commanding your vehicle’s accessories with a simple swipe of your thumb, allowing you to stay focused on the road or trail ahead. The sPOD SourceLT Mini 6 Steering Wheel Kit’s user-friendly interface makes it easier than ever to access your UTV’s lights, whips, helmet pumpers, radio controls, and more.
Equipped with built-in Bluetooth technology, you can program and system from any wireless device via the sPOD App, with a wide range of programming options available, including output dimming, strobing, flashing, master-slave functions, memory, auto power-up, momentary settings, input, and more.
What sets this product apart is its impeccable design. Underneath the steering wheel plate, you’ll find a coiled cable that ensures zero binding when turning the wheel from lock to lock. This thoughtful engineering guarantees that your sPOD system seamlessly integrates into your vehicle’s steering mechanism, preserving the smooth and responsive handling you expect.
sPOD Mini 6 Wheel Kit control switch for Polaris RZR Pro R
A single ethernet cable extends discreetly behind your dashboard to connect with the Source LT module, conveniently mounted in the upper footwell area. This minimalist setup eliminates the need for cumbersome relays, wiring looms, and circuit fuses, making it one of the simplest solid-state power management systems on the market today.
Key Features of the sPOD SourceLT Mini 6 Steering Wheel Kit:
Control up to 6 accessories with ease.
100 amps of total power management capacity.
Seamless integration with Polaris RZR steering wheel.
Bluetooth control, flash, dim, strobe, momentary.
Coiled cable design for unrestricted wheel movement.
Simplified installation with no relays or circuit fuses.
Integrated low-voltage cutoff battery protection.
12-position terminal block for enhanced connectivity.
Direct integration for the Polaris RZR Pro XP, Turbo R, and Pro R models.
sPOD Mini 6 Wheel Kit for Polaris RZR Models
The sPOD SourceLT Mini 6 Steering Wheel Kit is poised to transform your driving experience, whether you’re conquering off-road trails or racing in Baja. It’s the ultimate solution for those seeking unparalleled control, safety, and convenience.
For more or to order, click here.
