SSR Motorsports Creates an Entirely New UTV in the SRU600LT
It seems times are very good for the modern UTV rider (and shopper) indeed. Not only are there an unprecedented number of offerings available from nearly every manufacturer on the map (and even many from companies who have typically shied away from the core ATV industry, like Kubota, Bobcat and Cub Cadet), it now appears domestic powersports distributor SSR Motorsports is joining the fray with a side-by-side all their own.
Calling it the SRU600LT, this new machine appears to boast some impressive specs such as a 594 cc liquid & oil w/fan cooled single good for 37.5 horsepower.
The entire spec sheet reads as follows:
ENGINE
Type Single Cylinder, 4 Stroke, Liquid & Oil w/Fan Cooled
Displacement 594 cc
Max Output 37.5 HP @ 6500 rpm
Fuel System EFI
Drive System Push Button 3-Way Locking Differential, 2WD, 4WD, Locked 4WD; Shaft
Transmission Auto CVT with (L/H/N/R)
CHASSIS
Front Tire 26/9-12
Rear Tire 26/11-12
Front Brake Dual Hydraulic Disc, Twin Piston
Rear Brake Hydraulic Disk, Self Adjust Parking System, Shaft Mounted
Front Susp Dual A-Arm 13 Travel
Rear Susp Dual A-Arm 16 Travel
DIMENSIONS
Overall Size 117 x 73 x 73 in.
Wheelbase 75.2 in.
Ground Cl 12.6 in.
Net Weight 1151 lbs
Fuel Tank 6.6 gal
MSRP
$8599
More information can be found on SSR Motorsports’ site.
