Suzuki Unveils Complete 2025 KingQuad Line
2025 Suzuki King Quad Complete Line
For 2025 it’s very good to be king.
Suzuki Motor USA, LLC (Suzuki) has proudly announced its second wave of 2025 ATVs with the return of the complete KingQuad lineup, with each new ATV now arriving with a standard, two-year Limited Warranty.
The KingQuad 750AXi Power Steering is not just a new ATV, it’s a KingQuad ATV.
KingQuad 750AXi Power Steering Line
The 722cc, DOHC, single-cylinder, liquid-cooled, four-stroke engine delivers strong low- to mid-range torque and impressive peak horsepower. The four-valve cylinder head has large 36mm intake valves and straight ports for superb cylinder charging efficiency. A sportbike-derived chain-and-gear camshaft drive system helps create a compact engine.
The Quadmatic CVT-type automatic transmission provides versatility and convenience with a fender-mounted gate-type shifter for high/low range selection. Its advanced engine-braking system helps reduce speed when riding downhill.
Handlebar-mounted push-button controls permit easy selection between 2WD, 4WD, and differential-lock 4WD. An override button on the left handlebar can be used to override the normal speed limiter when getting out of mud.
The electronic power steering system has higher capacity than the prior generation for significantly reduced steering effort that also damps vibration and jolts to the rider.
To increase rider comfort and towing capacity the KingQuad’s frame has thick-wall steel tubes and reinforced brackets in key areas.
Independent double A-arm front suspension (6.7 inches of wheel travel) and the fully independent, A-arm/I-beam rear suspension (7.7 inches of wheel travel) use four large diameter, gas-charged shock absorbers with five-way spring preload adjustment.
Available in Flame Red, Terra Green, or Desert Beige, the bold, angular bodywork features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
Dual hydraulic front disc brakes provide consistent braking performance, while the sealed rear brake’s clutch-type design is highly durable with reduced unsprung weight and minimal maintenance requirements.
High traction 25-inch Carlisle tires are mounted on strong steel wheels with a durable, powder-coated matte black finish.
35-watt handlebar-mounted headlight and dual, fender mounted 35-watt headlights (with high- and low-beam settings) are part of the KingQuad’s distinctive bodywork. The multi-function instrument panel has excellent visibility and provides service reminders based on running time or mileage.
Rugged front and rear steel-tube cargo racks have high-impact plastic carrier covers that shield cargo from wear. The standard receiver-type trailer hitch receiver and hitch mount makes it easy to move equipment with the KingQuad’s generous towing capacity (up to 1322 pounds).
Each new KingQuad is supplied with a two-year Limited Warranty, that is much longer than other ATV warranties. Longer coverage and other benefits are available through Suzuki Extended Protection (SEP)
2025 Suzuki KingQuad Complete Line Buyer's Guide
2025 KingQuad 750AXi Power Steering
MSRP $9,879
Suzuki, the inventor of the 4-wheel ATV, has created the world’s best sports-utility quad with bold styling plus more capability and reliability than ever before. The legacy of the iconic KingQuad remains fresh and exciting, and is ready for you to join its history. The KingQuad 750AXi Power Steering helps tackle challenging terrain with the capabilities that only a KingQuad possesses.
2025 KingQuad 750AXi Power Steering SE
MSRP $11,529
The bold, angular bodywork is molded in a stunning Armored Blue Gray color and features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
High traction 25-inch Carlisle tires are mounted on cast-aluminum wheels with a blacked-out, matte black finish.
2025 KingQuad 750AXi Power Steering SE Camo
MSRP $10,279
The bold, angular bodywork is coated in the outdoor-ready True Timber Kanati Camouflage pattern and features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
2025 KingQuad 750AXi Power Steering SE+
MSRP $11,529
The bold, angular bodywork is coated with the unique Cast Carbon pattern and features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
KingQuad 750AXi Line
Available in Flame Red or Terra Green, the bold, angular bodywork features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
This KingQuad features dual hydraulic front disc brakes and a sealed rear brake. The rear brake’s clutch-type design is extremely durable with reduced unsprung weight and minimal maintenance requirements.
The 35-watt handlebar-mounted headlight and dual, fender mounted 35-watt headlights (with high- and low-beam settings) are part of the KingQuad’s distinctive bodywork. The multi-function instrument panel has excellent visibility and provides service reminders based on running time or mileage.
The rugged front and rear steel-tube cargo racks can accept Suzuki’s accessory high-impact plastic carrier covers that shield cargo from wear. The standard receiver-type trailer hitch receiver makes it easy to move equipment with the KingQuad’s generous towing capacity (up to 1322 pounds).
Each new KingQuad is supplied with a two-year Limited Warranty, that is much longer than other ATV warranties. Longer coverage and other benefits are available through Suzuki Extended Protection (SEP).
MSRP $9,829
KingQuad 750AXi – The 2025 KingQuad 750AXi continues the legacy of the iconic KingQuad and provides more capability and reliability. Equipped to help tackle challenging terrain with the capabilities that only a KingQuad possesses, the 2025 KingQuad 750AXi is ready for any chore.
KingQuad 500AXi Power Steering Line
A powerful, 493cc, SOHC, single-cylinder, liquid-cooled, four-stroke engine is tuned to produce a wide powerband with strong top-end power. The engine is canted forward for a low center of gravity, resulting in reduced engine height and lower seat height.
Electronic power steering system has higher capacity than the prior generation for significantly reduced steering effort that also damps vibration and jolts to the rider.
The dual hydraulic front disc brakes provide consistent braking performance, while the sealed rear brake’s clutch-type design is highly durable with reduced unsprung weight and minimal maintenance requirements.
The rugged front and rear steel-tube cargo racks have high-impact plastic carrier covers that shield cargo from wear. The standard receiver-type trailer hitch receiver and hitch mount makes it easy to move equipment with the KingQuad’s generous towing capacity (up to 1322 pounds).
2025 KingQuad 500AXi Power Steering
MSRP $9,879
KingQuad 500AXi Power Steering – The 2025 KingQuad 500AXi Power Steering helps tackle challenging terrain with the capabilities only a KingQuad possesses. The electronic power steering system has higher capacity than the prior generation for significantly reduced steering effort that also damps vibration and jolts to the rider. Suzuki has created the world’s best sports-utility quad with bold styling plus more capability and reliability.
2025 KingQuad 500AXi Power Steering SE
MSRP $9,879
Molded in stunning Armored Blue Gray color, the aggressive bodywork features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
2025 KingQuad 500AXi Power Steering SE Camo
MSRP $10,279
Outdoor-ready True Timber Kanati Camouflage pattern coats the aggressive bodywork that features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
2025 KingQuad 500AXi Power Steering SE+
MSRP $10,529
Coated with a distinctive Cast Carbon pattern the aggressive bodywork features high-clearance fenders that offer great protection for the rider. Refined panels simplify maintenance needs, such as oil level checks and fuel and air filter service.
KingQuad 500AXi Line
MSRP $8,229
The KingQuad 500AXi is not just an ATV, it’s a KingQuad ATV. Suzuki, the inventor of the 4-wheel ATV, has created the world’s best sports-utility quad with bold styling plus more capability and reliability. The legacy of the iconic KingQuad remains fresh and exciting and is ready for riders to join its history. The 2025 Suzuki KingQuad 500AXi helps tackle challenging terrain with the capabilities that only a KingQuad possesses.
KingQuad 400FSi Line
The KingQuad 400FSi’s fuel-injected, 376cc, four-stroke, four-valve engine produces efficient power and drivability. Class-leading fuel injection smooths power output and provides excellent cold starting. This system uses 3-D maps for optimum fuel injection and ignition to provide a responsive throttle and emissions compliance.
Durable five-speed manual transmission with semi-automatic clutch with reverse allows the rider to select the ideal gear for maximum traction and fuel efficiency.
Select 2WD or 4WD with the flip of a handlebar-mounted lever. The shaft drive system is dependable, durable, and is virtually maintenance-free.
Independent front A-arm suspension and a dual-shock rear suspension offers smooth performance and remarkable ground clearance with 6.7 inches (170.1 mm) of front and rear wheel travel.
Dual front hydraulic disc brakes feature calipers with large, 34mm pistons and wide brake-pad surface areas for ample stopping power while providing outstanding durability.
Large, 4.2-gallon (16.0 L) fuel tank provides outstanding riding range. Suzuki’s legendary and plush T-shaped seat is comfortable for short or long rides.
Sporty Terra Green bodywork features sharply angled, high-clearance fenders while the full steel cargo racks help tackle outdoor tasks.
Large, 25-inch Carlisle tires with aggressive tread offer consistent traction in wet conditions, yet make for a quiet, smooth ride on hard-packed trails. The tires are mounted to rugged steel wheels that are powder-coated with a durable matte black finish.
Each new KingQuad is supplied with a two-year Limited Warranty that is much longer than other ATV warranties. Longer coverage and other benefits are available through Suzuki Extended Protection (SEP).
2025 KingQuad 400FSi
MSRP $6,999
For riders who favor a sportier performance, the 2025 Suzuki KingQuad 400FSi features a five-speed manual-shift transmission and semi-automatic clutch. This engine is always willing as it cranks out an impressive amount of torque and has an incredibly wide powerband for exceptional performance on the trail or on the job. A long-lasting, high-performance iridium spark plug and refined Pulsed-secondary AIR-injection (PAIR) system help provide outstanding fuel efficiency and impressive performance.
2025 KingQuad 400FSi Camo
MSRP $7,549
True Timber Kanati pattern camouflaged bodywork features sharply angled, high-clearance fenders while the full steel cargo racks help tackle outdoor tasks.
KingQuad 400ASi Line
The KingQuad 400ASi’s fuel-injected, 376cc, four-stroke, four-valve engine produces efficient power and drivability. Class-leading fuel injection smooths power output and provides excellent cold starting. This system uses 3-D maps for optimum fuel injection and ignition to provide a responsive throttle and emissions compliance.
The Quadmatic transmission is a fully automatic, CVT (continuously variable transmission) with selectable high/low sub-transmission and reverse for maximum traction and fuel efficiency.
Sporty Flame Red or natural Terra Green bodywork features sharply angled, high-clearance fenders while the full steel cargo racks help tackle outdoor tasks.
Large, 25-inch Carlisle tires with aggressive treads offer consistent traction in wet conditions, yet make for a quiet, smooth ride on hard-packed trails. The tires are mounted to rugged steel wheels that are powder-coated with a durable matte black finish.
2025 KingQuad 400ASi
MSRP $6,999
Whether you are working hard or getting away from it all, the 2025 Suzuki KingQuad 400ASi helps you every step of the way. The fully automatic Quadmatic transmission has 2WD and 4WD modes to manage rough trail conditions while completing even the most demanding chores. Along with exceptional engine performance across the powerband, its high-performance iridium spark plug, and Pulsed-secondary AIR-injection (PAIR) system help provide outstanding fuel efficiency and impressive performance.
2025 KingQuad 400ASi Camo
MSRP $7,549
The True Timber Kanati pattern camouflaged bodywork features sharply angled, high-clearance fenders while the full steel cargo racks help tackle outdoors tasks.
2025 KingQuad 400Asi SE
MSRP $7,649
Unique Armored Blue Gray bodywork features sharply angled, high-clearance fenders while the full steel cargo racks help tackle outdoor tasks.
