300 Bayou oil leak at rear driveshaft again
I replaced the seal where the driveshaft goes into the engine. It has only been ridden a couple of times and is leaking again. Engine oil is going into the rear diff. It has flooded the diff and is in the rear brake drum. Could there be a return hole plugged and not letting the oil return to the sump? Also the right side engine cover was removed shortly before this problem started, I was wondering if there could be any connections. Could the seal around the output shaft on the engine be bad and flooding the seal that i replaced? Thanks for any help!
This will sound stupid but it was my problem. I have a 92 Bayou and oil kept getting into the Boot so I thought it must be the seal so I put a new seal in. The problem was that the inner portion of the drive axle had worn through. Oil was not coming by the seal it was coming through the hole in the shaft. New shaft no oil leak.
Hope it helps
Hope it helps
That is correct. The shaft slides into the gear box. The seal keeps oil from coming around the shaft but if a hole has worn in the midded then oil willl come right through it. I kept thinking it was my seal until I took it to a dealer and he saw it. I an not certian if this will allow it into the rearend but I know the upper boot will fill up.
The oil seal around the output shaft could cause the leak for sure. You would also want to check the backlash and side play of the output shaft. Looking at the service manual pics I have been unable to see the plug you are looking at. It sure looks like a good place to start. You mentioned the oil was leaking out of the axle and into the brake drum the seal there may also be gone. The bearing kit for that is from ( All *****, bearing & components) part #25-1275 web site GOallballs.com Good luck on the repair!
Thanks again nmhuntr and mudfinder
I removed the cv joint and managed to get the ***** and cage out. Inside the cv housing is a freeze plug type plug. It has a hole worn in it and is letting oil travel down the splines into the joint and on down the driveshaft. A new shaft is almost $400.00 so I may see if a car freeze plug will work. Thanks for the help!
