HOW TO carb adjustment on any Chinese atv. Kazuma, Yamoto, Redcat, Baja, Sunl, etc...
Old May 22, 2009 | 07:07 AM
  #161
NickNitro's Avatar
Hi everyone,
I just got a used 50cc ATV with the Honda style motor. It was pretty much in pieces and I now have it all put back together.
For carb adjustments - it is running, but doesn't have much power.
I set the needle on the second notch from the top - which puts the needle further down.
I only have an idle and air screw - the air screw is almost all the way in - maybe a quarter turn out.
Should I adjust the needle to allow for more fuel and then more air? I am in a warm climate - so cold starting shouldn't be a problem.
Thanks....
Old May 22, 2009 | 09:12 AM
  #162
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would start with the air screw at 1.5 turns out. .5 turns out is sort of like having the choke on.. air screw is good for air control from idle to approx 1/4 throttle.
The needle allows fuel to pass thru the main jet. lowering the clip(raising the needle) allows more fuel into the mix.
Old May 22, 2009 | 09:44 AM
  #163
NickNitro's Avatar
Hi mywifesquad,
Thanks for the response on this and my previous question on what type of ATV.
So, it idles fine but it doesn't have any good thrust when I give it gas. I can pretty much put the air screw almost all the way in without it dying.
Am I not getting enough fuel? I started at 2 turns out on the air, but it didn't idle very well. I noticed that if I provided less air it would idle better by covering up the air filter. Now I have the air screw probably 1/2 turn out.
I don't think the air screw is where my problem is - I was wondering if it was my needle setting. I have the needle set on the second notch down from the top which would lower the needle and restrict the fuel.
Thanks,
Old May 22, 2009 | 09:56 AM
  #164
KTM Patrol
Former Chinese POW!
Your welcome...I just realized this is a 4 stroke (reading too fast again)..its a fuel screw on a 4 stroke not a air screw..Did you clean the carb at all before putting the quad back together?
Old May 22, 2009 | 10:28 AM
  #165
KTM Patrol
Former Chinese POW!
Does this still have the stock spark plug?
Old May 22, 2009 | 10:36 AM
  #166
NickNitro's Avatar
Yes - I cleaned it. Pulled it apart and dipped it.
So - two screws - one is idle and one is fuel not air, my mistake.
It idles well with the fuel screw almost all the way in and the needle set down.
Old May 22, 2009 | 10:38 AM
  #167
NickNitro's Avatar
I am pretty sure it is not the original plug - I don't have it in front of me, but I thought it was cr6hsa
Old May 22, 2009 | 10:43 AM
  #168
KTM Patrol
Former Chinese POW!
This is strange...most of these run very lean from the factory...yours seems to be rich.. definitely not a vacuum leak. any way the choke is on or partially on?
Old May 22, 2009 | 10:56 AM
  #169
NickNitro's Avatar
Choke is off - I don't know the history of this ATV, but the carb was definitlely not set correctly. If it is running rich - I guess I want to set the needle down as far as possible - right?
Old May 22, 2009 | 11:11 AM
  #170
KTM Patrol
Former Chinese POW!
Yes lower the needle as much as possible(raise clip)..what elevation are you at? Also what kind of air filter? have you tried running it without the filter?
