Jetmoto 150 CVT maintenance
Old Sep 12, 2008 | 03:39 AM
Sawyer's Avatar
Default Jetmoto 150 CVT maintenance
Hey Outofline mine is different. Same drain plug but I do not have the top one that you got there. They must have several differnt product runs on these things. Looks to me I have to pull the CVT cover off or something.
Old Sep 12, 2008 | 12:14 PM
outofline's Avatar
Sawer does your shifter setup look like mine? If it's the new style can you post a picture of it!
Old Jan 2, 2009 | 05:55 PM
windtrader's Avatar
I just saw your shifter photo and had to chuckle a bit as I remember the comments you had about the shifter's minor issues. I assumed you had the same shifter as mine but you can see the later ones are different.
Also, I went on a hunt to find the cvt transmission filler plug and like Sawyer, I could not find any visible plug. It must be under the cover. The drain plug is in the same place.
Old Jan 2, 2009 | 08:20 PM
outofline's Avatar
Kind of like the looks of mine better, only have had one with the problem but feel it's something inside the gear box that is causing it to pop out of drive. It does ot do it anymore, but I had to adjust the shifter so it's quite hard to shift!
Old Apr 30, 2013 | 01:01 PM
  #15
hakim828's Avatar
Where can i get a shifter fork? I looked in every possible website. Can a Kazuma fit? Please help i dnt know what else to do.
dannytas
Sep 26, 2017 06:31 PM
Alex G.
Sep 11, 2017 11:38 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
