110 kazuma quad problem
Old Jul 20, 2009 | 12:05 PM
chomps's Avatar
Post 110 kazuma quad problem
Hi,
Had a blown head gasket on my quad and I replaced the head and cam and now i can't get it to run. It seems like the timing is not right. If someone can tell me how to set the timing, send me a line. I'll appreciate it.
Old Jul 21, 2009 | 09:07 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum chomps!
Did you align the cam/sprocket with the crank when you put it back together?
Old Jul 21, 2009 | 01:43 PM
chomps's Avatar
well i noticed that the sprocket has a dot what part of the crank should i align the dot to?
Old Jul 21, 2009 | 03:18 PM
KTM Patrol
Former Chinese POW!
The crank should be at the "T" on the side of the flywheel(lined up with the poimter on the case.....If there is one dot I would put it at the top of the rotation while the T on the crank crank is lined up with the pointer on the case...
Old Apr 5, 2010 | 12:57 PM
SPARKY69's Avatar
Did you get the timing set. If so how did you do it? I think i am having the same problem with mine. thanks
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
moneyman01
Jul 11, 2015 08:50 PM
DTroyer01
Jul 3, 2015 07:34 AM
merryman
Jun 27, 2015 03:31 AM
