oil cahange directions
Old Sep 8, 2009 | 07:37 AM
bostonadams2's Avatar
Default oil cahange directions
i need a step by step diagram on how 2 change oil on a 110cc sunl. including drain plug location and oil type and oil capacity
Old Sep 8, 2009 | 08:28 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The drain plug is the bolt on the bottom of the engine that fits a 17mm wrench..Best to drain the oil when its warm and let it drain for 15-20 minutes..Tighten the drain bolt after draining. Filler hole is on the right side of the engine (when sitting on the quad) towards the back..Most hold just under a qt and I use Valvoline 10wt-40..
Whitelx1
Oct 2, 2015 10:55 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
