BMS 50 power loss after 5 minutes
Old Sep 14, 2009 | 01:46 PM
erikdane's Avatar
Default BMS 50 power loss after 5 minutes
My daughters' BMS 50 has developed a problem that I need help with. It starts and runs fine for 5-10 minutes, then dies. When I try to restart it, it will start and idle only. Once any more throttle than an idle is applied it will simply die again.
I have tried unscrewing the gas cap thinking it is a possible venting problem, but that did not seem to help. Finally, once the engine cools down completely it will run fine for another 5-10 minutes.
Any ideas will be greatly appreciated.
Thank you.
Old Sep 14, 2009 | 03:04 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum erikdane!
Next time it dies i would check for spark..you can do that by taking the plug out and holding it next to the engine(while its hooked up to the plug wire and your cranking the engine over) If it doesnt have spark then but gets it later Id guess the coils fails when it gets hot....
Old Sep 14, 2009 | 03:53 PM
erikdane's Avatar
Default It starts, but won't run higher than idle
Thank you for the quick response.
If it starts does that rule out coils? It will start, but won't run any faster than idle. I am at work right now but will check for a spark tonight (assuming no rain).
Old Sep 14, 2009 | 05:09 PM
KTM Patrol
Former Chinese POW!
Im wondering if it has a weak spark, should have been more specific...a good spark will be blue...a yellow spark is weak...
Does the fuel line get close to the engine and or exhaust pipe? could be vapor locking when it gets hot?
Old Sep 14, 2009 | 08:35 PM
erikdane's Avatar
Fortunately no rain so I was able to investigate further. I was unable to remove spark plug (one of the kids got into my toolbox) but I was able to keep the engine going by choking it and feathering the throttle carefully. One thing I did notice was the rear brake would get extremely hot after riding. It was as if the brake locked and wouldn't release. I took an allen wrench and slightly loosened the nuts, which seamed to release some of the pressure on the brake. However, the brakes would not work well enough to trust my 5 & 6 year olds driving.
I tried to grease it but the zerk is plugged. Is it possible this could be part of the cause of my problems? The engine seemed to run better the longer it ran. After about 45 minutes of constant running it barely hesitated except when under the most strain.
I guess I have two questions...first, how do I properly adjust the brake so it doesn't hang up and put undo resistance when the brake isn't applied, while still having enough braking to stop the atv when necessary? Second, I'm planning on replacing the zerk, any other suggestions?
Thanks in advance.
greg74
Sep 10, 2019 03:03 PM
mtdewmn
Jan 19, 2017 12:13 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Chocobamofo
Jul 10, 2015 07:46 PM
