150 falcon kazuma
Old May 10, 2010 | 09:04 PM
motordaddy13's Avatar
Default 150 falcon kazuma
im working on on for a friend carb was shot from sitting to long .he bought a new one works fine,haveing said that the auto choke does not work ,,any suggestions,i need a wiring digram for this machine to,,thanks Motordaddy13
Old May 10, 2010 | 11:09 PM
LynnEdwards's Avatar
Electrical Expert
Most 150cc machines are wired similar (though the wire colors might not be exactly the same). Check this link:
http://forums.atvconnection.com/chin...se-stator.html
On page two there is a generic 150cc wiring diagram. If it is the bystarter valve (autochoke) wiring you are troubleshooting then there is an alternate way it could be wired. In the above linked diagram the bystarter valve is powered from the 5 pin regulator, which in turn gets its power from the stator raw AC voltage. Another common way to wire it up is to take one side of the stator battery charge winding (raw AC voltage) and feed it through a 10 ohm power resistor to the bystarter valve. The other side of the bystarter is grounded.
Are you sure the bystarter isn't working? There is a test routine here:
http://www.anythingatv.com/Technical...leshooting.htm
Choose the electric choke test from the menu.
Old May 11, 2010 | 12:17 AM
thanks man you answered my needs ill hook this guy up this weekend,, ill let you know the results,,motordaddy13
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
