Leaking Intake Valve
Old Jun 3, 2010 | 10:41 PM
tastyatv's Avatar
Default Leaking Intake Valve
I have a little 100cc, not sure of brand without looking, but after having trouble getting it started, I narrowed it down to a leaking intake valve. If I put gas in the intake/exaust whatchamacallit, where the sparkplug is poking through, the gas leaks through the intake valve. It takes about 30-60sec to empty.
I picked up some emory cloth, and plan on trying to clean the valve to see if I can get it to seal better. But if it comes down to it, I need to replace the valve.
I've looked on youtube, and google, but need instructions on how to go about removing/replacing. I have no idea where to start.
Thanks!
Old Jun 4, 2010 | 10:02 PM
tastyatv's Avatar
No one?
Old Jun 5, 2010 | 06:55 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum tastyatv!
The head will need to be removed from the engine..and you will either need to buy a valve spring compressor or make 1 out of a c clamp. The valve spring needs to be compressed so you can get the 2 small valve keepers out(valve keepers are small tapered tube halves that catch a groove in the valve and spring cap to keep the valve assy together). Then you could either lap or replace the valve.
Old Jun 8, 2010 | 12:46 AM
tastyatv's Avatar
Thanks for the information! Do you have any links to explain further how to make a c clamp compressor, and how to correctly lap the valve?
Old Jun 8, 2010 | 08:31 PM
D.Vanhorn's Avatar
You have to cut out the center of the clamp on the flat fixed end. The hole has to be big enough to get the keepers out & back in. Use a clamp that has a big flat head so it will compress the retainer evenly. Hope this helps.
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
Kenidah
Sep 7, 2015 07:50 PM
DM2015
Sep 7, 2015 10:36 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
