Dead in Michigan
Old Jul 1, 2010 | 09:37 AM
spolando's Avatar
Default Dead in Michigan
My son has been riding his CPI chinese quad for a month now no problems. After a pit stop he went to start it and the electrical is dead (no power to starter switch, gear position illumination, etc.). I figured battery was dead. To my surprise battery is fully charged. I've got 12v at the solenoid. Checked all my connectors and they are clean and tight. Any help?
Old Jul 1, 2010 | 11:46 PM
LynnEdwards's Avatar
Electrical Expert
Check the main fuse.
Then check the ignition switch fro switched 12 volts.
These two items sit in the way of the battery voltage getting to lights, etc.
Also try turning on the ignition, disablng any kill switches and jump the starter solenoid with a screwdriver. Doe the starter turn? Does the quad start?
Do you need more detailed explanations on how to do this? You'll need a meter of course.
Old Jul 2, 2010 | 08:02 AM
spolando's Avatar
Lynn, you are the man! Initially I checked the fuse (old bus type) and it looked like I had a solid wire. After noticing a replacement in the fuse case and comparing the appearance I swapped them out.....bingo. Simple fix saved me a bunch of time with the meter. Ever think about doing a flow diagram trouble shoot? I know I'd buy one. Thanks again and have a great 4th!
Scott
Old Jul 2, 2010 | 10:47 PM
Electrical Expert
Cool. Glad you were able to fix it .
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
cody500ho
14
Aug 14, 2015 05:03 PM
