start the 110 without a remote
Old Jul 16, 2010 | 01:09 PM
cholierose's Avatar
Default start the 110 without a remote
my son just got a new tao tao 110. he loves it but we can not start it with out the remote. there has to be a way to do it. turn the key and press the start should work- but it doesnt. if someone knows- please help me. thanks
Old Jul 16, 2010 | 01:24 PM
cholierose's Avatar
any help would be great!
Old Jul 16, 2010 | 11:18 PM
LynnEdwards's Avatar
Electrical Expert
Let's start with the simpler stuff, then if necessary dig in deeper.
There is a safety interlock on almost all quads that require you to have the brake applied before the starter will engage. The reason for this is the same as the interlock on your automatic transmission car that keeps you from starting it up in gear and lurching into something.
To test this interlock: Turn on the ignition and apply the brakes. Look at the brake light. Is it lit up? If you can manage to fiddle with the brake lever(s) and get the brake to light up press the start button while the brake light is lit. Can you get the brake light to light? If so, can you get the starter to crank while the brake light is lit up?
There are other causes of this as well, but brake switch problems are overwhelmingly the most common.
The remote start bypasses the brake safety interlock (why they would design it that way is beyond my comprehension, but is the way it is...).
To dig deeper you will need a volt meter so we can trace the power from the battery to the starter solenoid and find out where it stops.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bigredjeep
Apr 10, 2020 02:55 AM
RticKwad
12
Jul 19, 2015 12:22 AM
1000gade
May 27, 2015 12:37 PM
trx430ex
Sep 13, 2000 04:56 PM
