kazuma 50cc wont start
Old Jul 23, 2010 | 12:57 AM
nike4life's Avatar
Default kazuma 50cc wont start
Bought a kazuma 50cc quad for my boy. Had to replace the coil and Carb. Started and ran good. Boy rode it today, started and stopped it 10 or more times with no problems. Now the thing won't even crank. Charged the battery and still nothing. Any ideas or suggestions would greatly be appreciated.
Old Jul 23, 2010 | 10:53 PM
kmejr09's Avatar
Does it make a clicking noise when you hit the start button? If it does and the starter is not turning the engine, it is probably the starter solenoid that is mounted somewhere underneath the quad. If there is not a clicking noise, I would suspect the brake switch is bad or has a loose connection. The brake handle (usually the left one) has to be depressed for the thing to start. There are two small wires going to the switch an the backside of the brake assembly. Jump those two wires together and see if it will start. If it does, the switch is bad or the connections on the switch are corroded. There is also a fuse usually near the battery that might be blown. Hope this helps.
Old Jul 23, 2010 | 11:14 PM
nike4life's Avatar
Default wont crank
This quad does not have a hand brake. It does have the starter switch and kill switch and also the light switch on the left handle bar. I checked the fuse and its OK. I have two positive wires and one negative wire. I hooked up just the light wire and ground wire to the battery and the light wouldn't even come on. I will try your idea with the starter switch. Ill let you know what happens tomorrow, I'm at work all night
now. Thanks for the idea.
Old Jul 25, 2010 | 11:29 PM
nike4life's Avatar
Smile running
Took the fuse holder apart. Checked fuse. Fuse was good
Replaced fuse anyway. FIRED RIGHT UP. WHAT A RELIEF. My brother in law has same exact quad and has had no problems. Knock on wood I don't have anymore.
Thanks for your help. Not to sound rude, but I hope I don't have to talk to you again. That would mean I'm having more problems.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
dcoleman
Oct 5, 1999 01:34 AM
