90cc Spark Plug Issue?
Old Aug 9, 2010 | 11:11 AM
pdm228's Avatar
Question 90cc Spark Plug Issue?
New to quads and mechanics, but a quick study. Bought a used Jetmoto 90cc. Started and ran fine, but when we got it home wouldn't start. Regular bike/atv shop wouldn't look at it b/c it was Chinese. Took it to a lawmower shop. Said it was the spark plug. Bought new plug, started and ran fine, but once it was turned off it would not start again. Disgusted I left it for a couple of days, then removed plug, cleaned it, replaced it, filled tank with gas and it started up again. ATV sat for a couple of days, again it would not start. Cleaned the spark plug again and it started. Is this a spark plug issue or something else???
Old Aug 9, 2010 | 02:14 PM
Jaster94's Avatar
each time you removed the spark plug and cleaned it, what kind of condition was it in? black, brown, white, gold/yellow? what color was the end of it? when it runs, how long does it run in between starts? 10 mins? 1 hr? 2 hrs? what brand of spark plug are you using? does it idle smooth after you change plugs and gradually get worse? OR, does it idle/run/rev normally the entire time you are operating the quad? in other words, how does the quad perform while running in between starts?
Old Aug 9, 2010 | 02:25 PM
pdm228's Avatar
The spark plug (NGK brand) is black when removed, even after only two starts. The first time it ran very rough, kept stalling (prior to a new spark plug). The second time it ran smooth, I started with the choke open and then moved it to half once it was warmed up and it ran fine. Since it has only been started and run 4 times it is hard to qualify (especially since as soon as I get it started my son wants to ride it). What kind of test should I perform to get a better feeling for this (warm up time, running time, number of starts, time between starts, etc)?
Old Aug 10, 2010 | 06:55 AM
Jaster94's Avatar
adjust your carburetor, it's running too rich.
Old Aug 11, 2010 | 08:45 AM
LT80's Avatar
LT80 Expert
If you have to run w/choke on, there is a problem. Clean the carb and then adjust if needed.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
hugemoth
Jul 20, 2020 03:28 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
D-Hagz
Jul 4, 2015 02:19 AM
