Roketa atv-250 Starting problem
Old Sep 6, 2010 | 08:01 AM
rpace78's Avatar
Default Roketa atv-250 Starting problem
The only way I can get it to start is to have it full choked. If not, it will turn off. A friend sadi I need to clean the carb, but I don't have a clue how or where it is. Does any one have a manual? Thanks for your help in advance!
Old Sep 6, 2010 | 08:19 AM
Jaster94's Avatar
your carb may be similiar to this one. should be located under your seat, next to engine just behind top head and before battery. black box connected to it should be the air filter. take screws out of bottom of carb after you've removed it and clean the jets. here's a link to help you out.
YouTube - how to clean a carb (float and jet style)
there are other videos that may have better quality and others that go more in depth. click around and see what fits your needs. most carbs are, in essence, fairly equal and the same when cleaning. main thing, make sure the jets are clean. then clean them again. then try it........
daisy-may
1) Engine problems..
May 28, 2014 09:51 AM
bartturner
Jun 2, 2008 07:19 PM
bartturner
May 29, 2008 05:00 PM
big4x4
Jul 27, 2006 02:07 PM
since1984
Jul 10, 2006 05:07 PM
