atv china 300cc
Old Sep 10, 2010 | 01:33 PM
ADIBORA's Avatar
Exclamation atv china 300cc
need timing marks on camshaft .please.
Old Sep 10, 2010 | 04:39 PM
BDIAgencies's Avatar
Head bolt torque is 29 lb/ft [oil the threads and washer]. Valve clearances are .006" both intake and exhaust. Cam timing is set with the T mark on the alternator aligned with the slash mark on the inspection window [be sure it is the T mark and NOT the F mark, they are very close together]. Cam timing is set with the slash marks aligned level with the gasket surface of the head/valve cover. Be sure to use a small blade screwdriver to unwind the cam chain tensioner while tightening the mounting bolt
I hope this helps....
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
