Hydraulic Rear Brakes setup in 90cc Chinese ATV
Old Sep 28, 2010 | 12:56 PM
alangsam's Avatar
Default Hydraulic Rear Brakes setup in 90cc Chinese ATV
My son rolled his ATV - everyone fine. however the accident basically broke the brake handle/brake reservoir on the handlebars. I have ordered a new rear brake system complete that should arrive today.
I am assuming it wont come with brake fluid so i was wondering what the setup sequence is once i have it bolted in place to get all of the air out of the line?
Also do i use standard dot 3 fluid?
Andy
Old Sep 28, 2010 | 06:20 PM
Mr.Firemouth's Avatar
I use normal DOT 3 brake fluid on my quads.
At the caliper on the rear axle is a bleed screw. Open this screw and gravity bleed the brakes by pouring fluid into the reservoir (keeping the reservoir 3/4 full as you go). Once you get fluid out of the bleeder at a steady flow, tighten the bleeder, press and hold the brake lever, and open the bleeder, allow the fluid to squirt out while still holding the brake lever down, and then close the bleeder tightly. Now release the brake lever. I repeat this step 3 times and the brakes are solid!
Hope this helps, Rich
Old Sep 28, 2010 | 06:26 PM
Jaster94's Avatar
my chinese stuff requires DOT 4 Brake Fluid. but to be honest with you, i'd like for someone to explain the difference between DOT 3 & 4. thanks...........
Old Sep 29, 2010 | 10:33 AM
alangsam's Avatar
Default more detail on brake bleed Rich
wow - very helpful. do i put the top back on the reservoir before holding the brake down and repeating or does it matter?
Old Sep 29, 2010 | 06:10 PM
Yes replace the cap during the pumping of the brakes.
Old Apr 16, 2020 | 11:03 AM
Yanick Sansregret's Avatar
Default My 110cc chinese atv has no rear brake reservoir, is it normal?
hiw can i fill it?
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
vlkster
Jul 28, 2015 11:35 AM
