Chinese quad 90cc
Old Oct 29, 2010 | 03:29 PM
ford123's Avatar
Default Chinese quad 90cc
I have a chinese quad its lights up and everything, but will not started. I check the fuses and everything still not getting a start up. Can the starter be the problem? It used to click when I was trying to start it, now it dosen't click at all. I have had problems with this thing since I brought it. I already put $600 into it and month later no start.
Old Oct 29, 2010 | 04:02 PM
Jaster94's Avatar
Default your quad problems
treat this like your car...does your car turn over and not start? then why replace the starter? define no start?...turns/cranks over with no start up of engine? no turnover/crank of engine? what?
i presume it turns over. define no start....presume starter turns over. do you have spark? pull spark plug with coil wire on, ground to engine and crank over the starter. does the spark plug spark? with spark plug out, is the spark plug wet with gasoline? does the carb have gasoline in it? open drain on float bowl to release/check for gasoline. i believe the "clicking" comes from the battery being low and the solenoid clicks. recharge your battery or jump it from your vehicle. check voltage of battery if you can't recharge it with charger. more info to come...depends on your response...thanks. be detailed in your responses....thanks.
Old Oct 29, 2010 | 10:24 PM
LynnEdwards's Avatar
Electrical Expert
...It used to click when I was trying to start it, now it dosen't click at all.....
I agree with Jaster94. Sounds like a discharged battery. Jump the quad to your car with a pair of jumper cables and see if the starter turns. Just be sure to get the polarity right: Plus to Plus and minus to minus. Does the starter tunr with jumper cables?
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
