Carb adjustment issues
Old Nov 15, 2010 | 09:35 PM
sofast's Avatar
Default Carb adjustment issues
I have tried using two carbs and have ended up with the same results. The only way i can fight this 110ST quad is to adjust the air mix screw a 1/4 turn out and the idle screw 1/2 turn out with the choke on with lots of starting fluid. once started and warm I can adjust the A-mix out to 1 1/2 and the idle 1 1/2. seems to run better with the choke on. I have great spark and about 80 psi on the cylinder. what do I do to make this start easier and run better
Old Nov 16, 2010 | 12:13 AM
Jaster94's Avatar
Default what?
adjust valves, reclean carb/jets, check for air leaks. i.e. cracked plastic intake/missing O-rings on intake at carb/etc.... please be conservative with starting fluid. the quad can get very used to and addicted to the ETHER BUNNY. no wonder you're losing compression. it's starting to wear the rings. keep an eye on oil consumption and any smoke when running.
Old Nov 16, 2010 | 07:31 PM
sofast's Avatar
well come to find out I only have 48psi. looks like I will be replacing rings
JBibb
Jul 4, 2015 10:16 AM
Ty Speece
Jul 2, 2015 04:59 PM
regiedina@gmail.com
Jun 20, 2015 03:19 PM
robj
Jun 15, 2015 08:45 PM
Joe04785
Jun 15, 2015 03:12 AM
