150cc
Old Nov 25, 2010 | 06:22 PM
g4s's Avatar
g4s
Arrow 150cc
fuel shut off valve was not letting enough gas pass thru.flow was too slow to keep carb full.
Old Nov 26, 2010 | 12:00 AM
LynnEdwards's Avatar
Electrical Expert
I'm thinking your post is in response to this thread?:
http://forums.atvconnection.com/chin...nk-atvs-2.html
I've had experience with two quads that were not passing enough fuel through the fuel shutoff valve to keep the carburetor full. The symptoms were easy starting, normal operation for a couple minutes, then the quad sputters, coughs, and dies. When you crank it immediately it won't start, but if you wait 30 seconds it starts right up and runs for 30 seconds. Then it sputters, coughs and dies.....
Quad one had a molding problem in the rotating plastic shutoff ball in the valve that was blocking fuel. I drilled the molding defect out.
Quad two had a 1/4 inch *water* shutoff valve installed which was bought at the local plumbing supply store. Over time the neoprene gasket in the valve swelled up from exposure to gasoline and blocked the fuel path. I replaced it with a valve designed for gasoline use.
dannytas
Sep 26, 2017 06:31 PM
frostphase
Aug 19, 2015 07:11 PM
Jaster94
3) General Discussions..
May 29, 2015 08:45 AM
elmer119
May 24, 2015 10:51 AM
