Atv Brake Adjustment on Chinese Quad
Old Dec 5, 2010 | 06:31 PM
Tramont's Avatar
Default Atv Brake Adjustment on Chinese Quad
My front brakes on my quad isnt working i have a 150cc avanti atv it brake cables in the front and hydraulic disk brakes in the back here is the link to look at them how do i fix them is anything brokeMy Atv - Living a Savage Life
Old Dec 5, 2010 | 09:10 PM
LynnEdwards's Avatar
Electrical Expert
The cables have thumb screw adjustments on them - exactly like the cable brakes on a 10 speed bicycle. Have you adjusted them?
Old Dec 5, 2010 | 09:34 PM
Tramont's Avatar
are you talking about the little **** looking things that are attached to the lever on a bike if so no i haven't and how do i
Old Dec 5, 2010 | 11:07 PM
Electrical Expert
Loosen the lock nut, then turn the adjusting screw out on each cable so that it essentially makes the brake cable housing longer. Since the center brake wire is a fixed length this starts to apply the brakes.
What you want to do is take up all the slack in the brake cable center wire so that when you apply the brakes using the brake lever the brake shoes will expand and press against the brake drum rather than expanding and not quite reaching the brake drum.
Once you have the brakes adjusted so that the front wheels spin freely with the brakes off, and they lock up solid with the brakes applied, then tighten up the lock nut.
Brake shoes wear down and get thinner, so this is an adjustment you need to do from time to time. You may want to take off the wheel, remove the brake drum, inspect your brake shoes to see if they are worn to the point that they need replacing.
Dame0927
Oct 29, 2015 10:13 PM
VRRRRT
Jun 27, 2015 09:38 AM
Ragtop
Jun 27, 2015 03:04 AM
UPLou
Jun 7, 2015 09:42 AM
RaymondT
May 26, 2015 08:14 PM
