Sunl 150 atv won't start
Old Dec 10, 2010 | 06:43 PM
oldman59's Avatar
Default Sunl 150 atv won't start
I have a Sunl 150cc and when you try to start the starter solenoid just clicks. Put another on that is working on my other Sunl 150cc and the same thing. Power is not getting past the solenoid to kick the starter in. Any thoughts would be helpful. Thanks.
Old Dec 10, 2010 | 11:34 PM
LynnEdwards's Avatar
Electrical Expert
There are several possibilities here.
1) Set your brake, make sure you are in nuetral, and turn on the ignition switch. Take a screwdriver and short the two big screw posts on the starter solenoid together (some sparking OK). Does the starter turn? Does the quad start up?
2) Try jumping your quad battery to your car (take extra care to get the polarity right). Does your starter turn now?
3) Measure the DC voltage right on the battery terminals while attempting to start the quad (i.e. solenoid is clicked). Make sure you are placing the meter leads right on the batery terminals - not the lugs on the terminals, or the wires in the lugs on the terminals. What voltage do you read? You should see a slight voltage drop when the starter solenoid goes "click", but it should *not* drop below 11 volts.
4) Repeat test 3 above only measure the voltage right at the starter motor while the solenoid is "clicked". Red lead on the starter motor post and the black lead on the starter motor frame. What do you measure?
This is a start. From your results we will have a better idea of which direction to go from here.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bigredjeep
Apr 10, 2020 02:55 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
