90cc ATV Boggy
Old Dec 22, 2010 | 06:26 PM
sofast's Avatar
Default 90cc ATV Boggy
Ok I have a 90cc engine. New piston, rings and valve adjustment. Running 150 psi on the cylinder. Timing is on the mark. The ATV starts decent with choke on. idles ok with choke off. poor acceleration from start. picks up ok once rolling. If I smash the throttle it bogs. The Air mix is adjusted an 1/8th turn open and the idle all the way in. This is close to the only way it will start. Not sure what exactly to do? I cleaned the carb and visually it looks clean and free from garbage. Float is in good working order. I got this quad from a cycle center. It started off as a 110ST and they put a 90cc motor in it. Maybe they used the wrong carb I dont know. Any advice would be helpful. thanks
Old Dec 23, 2010 | 07:18 PM
sofast's Avatar
Any advise please. Im trying to take the kids riding this weekend. thanks
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
