110cc automatic clutch adjustment
Old Apr 8, 2011 | 12:20 PM
lotus7's Avatar
Default 110cc automatic clutch adjustment
I want to increase the rpm that the clutch will grab at.Following the manual and youtube instructions I cant get the adjustment screw to be where I want it. After removing the locknut I can push the threaded ajustment screw in and out of the side of the engine? Should it not be threaded in the side case of the engine?
What am I doing wrong? or is something broken?
Old Apr 12, 2011 | 01:47 AM
lotus7's Avatar
Default automatic transmission continued
I forgot to mention-I raised the rear end up on a jack,started the engine up on idle speed,removed the locknut from the clutch adjustment screw and no matter if I pushed the setscrew in all the way or let it return back out all the way,the rear axle still would still want to turn.
Why,on idle speed would the clutch be engaging enough to turn the wheels no matter what position the adjustment screw is in?
Old Apr 12, 2011 | 06:15 AM
Jaster94's Avatar
i would think it's turning because you have no weight/restriction/friction resistance on the axle to stop it if you have it jacked up and not bound to the ground.. freewheel mode i reckon.
Old Apr 14, 2011 | 07:19 PM
Mainstreet's Avatar
With many of the Chinese full autos, the "adjustment" screw has no relative effect on clutch adjustment. Depending on your clutch design, it may be working for you just as it was intended.
Old Apr 25, 2011 | 05:32 PM
Dynamo55b's Avatar
Sounds about right LOLJust another screw you can turn to oblivion and does nothing
Old Apr 26, 2011 | 08:40 PM
OneTenCC's Avatar
Well.. hey. Look at the positives. Atleast it doesn't twist apart like bubble gum like some of the hardware will!
Old May 6, 2016 | 02:30 PM
bi11y T. Stroke's Avatar
Default make her weigh more.
My experience moving kids of all levels up a size or class in machine is because the former machine is under powered, under clutched, under sized, and under sprung for their current weight, and experience. But..............to go up 10cc is impractical, where 75-100 cc always seems not over powered, but over sprung for their weight. A 75 lb kid just won't settle 100 lb springs. But in order to grow into it, you don't wanna reconstruct mounts just to reverse it months later, or spend more money on shocks or tunning, especially for a Chinese unit. So why not make the rider heavier???? Be suprized what 25 - 35 lb of balast split and hung from grab bar, and between a arms will due. Not knocking the whole cut chop glue ideas, but personally bolt on today, unbolt in a season to keep rider and machine balanced is quicker safer and avoids voiding what little warranty it may have??? FOOD FOR THOUGHT FELLAS .
Old May 9, 2016 | 09:47 AM
Zrock's Avatar
Super Quad Patrol
I would rater get softer shocks/springs then make a kid have to deal with the extra weight of the machine. Increasing the weight of the machine is dangerous to the kid. their is a reason they make the kids machines lighter. For shocks i found a set of a bigger machine had a much softer spring rate..
Bratman2
Aug 6, 2022 01:42 AM
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
