starter not cranking on 2006 SLA 109 chineese quad
Old Apr 10, 2011 | 12:52 PM
fixermaybe's Avatar
Originally Posted by Billy bob
I had the same problem with my 2000 polaris 325 magnum the starter went bad and did not crank. But if you tap it while trying to start it should crank.
yes that is an old school trick which was something I had tried during my initial trouble shooting....thank you for your response
Old Apr 10, 2011 | 04:08 PM
Jaster94's Avatar
well, whodathunkit?! glad you found the starter! let us know how it goes!
Old Apr 21, 2011 | 07:12 PM
fixermaybe's Avatar
Default ok the sarter is in
new baterry and starter...what a pita that ws to put in...with the little chai and what not. Now it cranks over and I have spark. But it cranks real slow. If I take the spark plug out it turns over great. I gues these things don't have any kind of copmression release?????
Old Apr 21, 2011 | 09:47 PM
450kodiak's Avatar
Did you charge the new battery?
Check battery ground cable at frame?
check solonoid mounting ground?
Was spark plug wet when you removed it?
Crankcase oil level?
Old Apr 21, 2011 | 11:01 PM
  #15
LynnEdwards's Avatar
Electrical Expert
What 450kKodiac said times two...
Old Apr 30, 2011 | 07:29 PM
  #16
fixermaybe's Avatar
Default got it running.
Changed the battery terminals as there were some weak conections in there so I clipped the wies and put new terminals on. The thing runs good! It is much faster then I thought it would be....even with my fat two hundred lb. azz on it. So this thing is for a 7 year old kid. Where is the govenor and how do I set it?...I need to turn it way back. I was thinking it had something to do with the idle screw. As when it started it was wound all the way in. I wound it all the way out then set it till it started idling smooth. Any help would be great!.... An owners manual would be sweet huh?...lol
Old Apr 30, 2011 | 08:32 PM
  #17
450kodiak's Avatar
There you go. Glad you got it going.
Is there not a govenor screw at the thumb throttle lever on handle bar?
Old Apr 30, 2011 | 09:48 PM
  #18
fixermaybe's Avatar
I didn't see one but I wasn't looking for one either. I will look tomorrow.
thanks
Old Apr 30, 2011 | 10:03 PM
  #19
Electrical Expert
I have a couple 110cc quad owners manuals. Is your's a 110cc quad? I kind of suspect so because of the way you described the chain and the starter motor as being a pain.
If your quad is a 110cc you may get a lot of useful info out of these manuals. 110cc quads are so generic that that they often identical in many respects.
These aren't full blown service manuals, yet they do contain routine stuff like valve adjustment, clutch adjustment, etc. If you want them send me your email address by private message. I'll attach them in a return email. You need to be able to receive 5 megabytes of attachment total. The manuals are in PDF format.
Old May 1, 2011 | 08:16 PM
  #20
fixermaybe's Avatar
I found the hole where the gov. screw should be. So I got a nut and machine screw and gov. it down. a little blue lock tite and it is now much more suitable for a 6 year old.
