What is wrong with my TaoTao ATA 110 ATV?
Old May 22, 2011 | 07:13 PM
Kksang9's Avatar
Default What is wrong with my TaoTao ATA 110 ATV?
I bought a TaoTao ATA 110 ATV. 4 stroke.
When I bought it the guy said it needs a new battery and the carburetor needs to be cleaned because it has been sitting for so long.
I took it home replaced the battery and bought carburetor and intake cleaner to clean my carburetor.
After I finished it put everything together and tried to start it, it just sounded like a car before it starts.
And it wouldn't start.
Then I decided to change the spark plug (last time I checked it does have a spark), and drain the oil and gas then refill it with brand new oil and gas.
Now when I try to start it, it sounds like it does when it has no spark plug in.
I assured the spark plug was connected and connected correctly.
I dont know what the problem could be. Please help.
Old May 22, 2011 | 08:56 PM
Jaster94's Avatar
well, i presume by "no start" it cranks/turns the engine over. with that said, is the spark plug wet with gasoline? do you indeed have spark now? have you checked for spark up against the jug? make sure all of your kill switches are in the correct position. things to look at and let us know what's next. thanks.
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
