Baja Wilderness Trail 400 ATV
#21
i have 2 baja wilderness 400s one needs a piston the other o just replaced tie rods and ball joints but the bikes not charging i was told ny ignotion was hooked up backwards and blew 2 reglators i tried i got my new one on there now bit im half sketchy about trying it as i just payed 100 in change for it and im afraid something will blow it anyone know if or what can blow a regulator
#23
Before you put power to regulator pull the fuse like I show in my video. Turn power on tap fuse. If it sparks something is wrong if it is a new regulator. Get somebody to check wiring I guess. I got a great regulator with overload protection from RM Stator for like under $50! Not a problem since. Also I bought excide battery. The Canadian tire ones are garbage & they lied never gave me money back after two of those quit assoon as it got below freezing. Never knew about recall. https://youtu.be/FR_sA-N96g0
#24
Yes they are a Yamaha clone. Parts interchange. Even volt reg and wiring is the same and interchangable. I have a 450 wolverine 4x4 and a Baha 400. The parts interchange between bikes. Even wiring. Only difference is the engine. Frame is virtually identical. As well as interchangable parts
Baha 400
Hi I must say I am very disgusted with my Baja 400. I am wondering does anyone know concretely if it is a Yamaha clone? I have heard makes several as well as honda on posts elsewhere
. I don't want to buy parts from Baja as they ruded me out & don't stand behind products or listen well. I bought this bike from Canadian Tire thinking it was serviced by them. I never used it so it went off warranty. I have only used it ten times. It nearly burnt my house down as main fuse never blew & regulator shorted smoldering away on it's own in my garage with a full tank of gas. Baja told me this is impossible, right. I then bought a new regulator 1 trip & luckily it failed near truck. I want to get it from a reputable dealer if possible as theirs are faulty. Anyone? Tossdart
#25
. I don't want to buy parts from Baja as they ruded me out & don't stand behind products or listen well. I bought this bike from Canadian Tire thinking it was serviced by them. I never used it so it went off warranty. I have only used it ten times. It nearly burnt my house down as main fuse never blew & regulator shorted smoldering away on it's own in my garage with a full tank of gas. Baja told me this is impossible, right. I then bought a new regulator 1 trip & luckily it failed near truck. I want to get it from a reputable dealer if possible as theirs are faulty. Anyone? TossdartThread
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
