2009 bmx 300cc idling problem.
Old Sep 26, 2011 | 07:41 PM
bsblhater's Avatar
Default 2009 bmx 300cc idling problem.
my utv will not idle. i cannot find any help or information to help me trouble shoot this problem. its got electronic idle control i rang out the sensor with a meter it was 18.4 ohms so i believe that is good but i dont know if its working as its suppose to. i took the carb apart and it has a slide and a butterfly in it. its like two different types of carb in one. it also has a accerator pump inside . i cleaned it the best i could. can anyone help. iam desperate to get this issue solved. i have only had the machine two weeks and it just up and quit and i could not get it started. i took the fuel filter out of it and put a smaller one in it. i dont know if this is a issue so iam going to put a bigger one back in it. i also thought the fuel pump was bad but it is pushing fuel i dont know if its enough i cant find any information on this machine and have been digging for several days. this is just the tip of a iceberg of the questions i have on this machine. does anyone know if this machine is capable of diff locking the rear end. i see the reverse and forward switch on the rearend and more wires going into another connector in the rear. i hate the one wheel peel on it.
thanks
jim
jim
Old Sep 27, 2011 | 02:25 PM
bsblhater's Avatar
still waiting for a expert opinion on this topic. helppppppppppppppppppppp
jim
Old Sep 27, 2011 | 05:58 PM
bsblhater's Avatar
come on guys. i figured it out. there is a needle jet missing out of the carb its probally been gone as long as i owned it. so now come on help me where can i find this jet without buying a 150.00 carb. i have a pic of the carb showing the jet and i can see it missing now. if i plug it with my finger it runs good then starts to get ruff and then take you finger away and it runs fine again for a few seconds. it needs that metering feature of that needle jet
jim
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
