rocketa atv ar 20,
Old Oct 10, 2011 | 08:12 AM
cjtim's Avatar
Default rocketa atv ar 20,
having trouble getting this atv to idle, no ajusting seems to help, any help?
Old Oct 10, 2011 | 04:30 PM
raenglehart's Avatar
Jets are clogged in the carb. Pull the card apart, remove the jets and clean out all the holes. This is quite common. I've had to do this with 3 of my quads this summer alone. Also, if you don't have an inline filter between the petcock and the carb, I strongly recommend installing one. They are only a couple bucks and can be found at any autoparts store. There are several threads on here with pics to show what I mean.
Old Oct 10, 2011 | 04:59 PM
cjtim's Avatar
Default clogged
ive cleaned it twice now, il give another try thanks
Old Oct 10, 2011 | 05:27 PM
Sometimes there's some junk in your fuel tank/lines that may be getting in there. If you have a magnifying lens, use it to inspect all the jet holes. I've done the multiple cleaning thing too and it gets frustrating to say the least, but then using the magnifying lens, I find more clogged ports that the naked eye just didn't detect. If all else fails, a new carb is only about $25-$30 off eBay............depending on what size your engine is (you didn't say).
Old Oct 11, 2011 | 02:42 AM
I've got the same thing going on with my 110cc right now......going to give it another go this afternoon when I get off work.
Old Oct 11, 2011 | 07:48 AM
cjtim's Avatar
was also looking for a wiring diagram 2007 rocketa 90cc
Old Oct 14, 2011 | 07:03 AM
Did you get your idle sorted? As I mentioned, I have a 110cc that was doing the same thing.....It took 3 times removing/tearing down/cleaning the carb, but It's running like a champ now.
As for diagrams, try this site. They are pretty hit/miss, but you may get lucky. Chinese Atv Wiring Diagrams - Chinese Engine Parts - Roketa Atv 110 Wiring Diagram - Buyang Atv 90
Old Oct 14, 2011 | 01:58 PM
cjtim's Avatar
Cleaned like 8 times even soaked it in carb cleaner for 4hours no luck, just ordered a new one, cleaned many carbs in the past, thanks for the diagram link
Old Oct 16, 2011 | 01:30 PM
cjtim's Avatar
no luck with cleaning did everything possible, replaced carb for 25 dollars runs great
Old Oct 16, 2011 | 10:48 PM
LynnEdwards's Avatar
Electrical Expert
Its hard to argue against just changing out a $25 carburetor compared to taking it apart 8 times.
But I must admit, I'm the stubborn type who would probably take it apart 10 times and still not order a new one .
