Jianshe 250 parts
Old Sep 8, 2012 | 06:56 AM
jianshe250's Avatar
Originally Posted by leonard graham
how much for transmission gear cluster
30 + shipping
Old Oct 16, 2012 | 07:09 PM
35Wailin's Avatar
Still got a starter relay? Mine is round on bottom, with four blade plug and an on board fuse.
Old Oct 17, 2012 | 09:51 AM
green15350's Avatar
Hey Trailblazer -- how much for choke controller?
Old Mar 18, 2013 | 07:59 PM
jianshe250's Avatar
many parts still available!
Old Nov 1, 2014 | 08:05 PM
  #15
MPDano's Avatar
I know this is an old thread. Once I figure out why my right gear cover is cracked, I might be hitting you up for some gears and a cover.
Old Apr 21, 2021 | 08:27 AM
  #16
Nate Dunwoody's Avatar
Default Jianshe parts.
Originally Posted by jianshe250
Still have parts available!
Do you still have the clutch basket and assemblies?
Old Apr 21, 2021 | 08:32 AM
  #17
I'm selling several brand new part for a 250 Jianshe.
Here is a list of parts:
Gaskets, head, base, case, intake, exhaust
Seals, engine, rear axle
Centrifugal clutch, clutch disks, & basket
Pistons, complete cylinder head, timing chain & tensioners
2 pair of brake shoes
crankcase cover ( starter motor side )
starter relays, choke controller, indicator lights, headlights, on/off main switch
ignition coils w/spark plugs
Used transmission gear cluster
Reverse / forward gear dog
Would anybody happen to have the rear axel housing(brake drum side) bearing and seal?
Old Apr 22, 2021 | 02:28 AM
  #18
Someone else on here posted wanting parts yesterday, may be worth a look. If it is just a bearing, they are standard sizes. If it has no markings, take the old one to a bearing supplier, they will measure inside dia, outside dia and width, and supply a replacement. Same goes for the seal, though measuring the shaft dia it runs on, is preferable for a seal. The parts in the other post look suspiciously like Yamaha ones, so it is possible Yam 250 bearing kits would fit, if all else fails.
Old Oct 9, 2021 | 05:51 AM
  #19
ruizrene513@gmail.com's Avatar
you still have the gear box
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
chammerbeck
Jul 17, 2015 08:06 AM
