Coolster 125 NO LOW END POWER!!!!!!!!!!!!
Old May 3, 2015 | 04:13 PM
  #21
Chuckq350's Avatar
just bought one yesterday for my son who is about 50 pounds also and having the same issues
Old May 4, 2015 | 09:19 AM
  #22
Zrock's Avatar
Super Quad Patrol
One thing to check before spending money on gearing is the rev limiter. If you have that little screw turned to far in they can get the extra power needed to climb hills.
Old May 4, 2015 | 07:30 PM
  #23
Chuckq350's Avatar
the engine seems to rev fine even if I back the throttle screw all the way out the atv wont pull. My garage concrete apron is about a 2-3 inch drop off into the gravel and unless you have a run at it will not drive up it acts like your sitting there slipping the clutch. I talked to the shop where I purchased it and turns out he is not a dealer and is a middle man on these and he said that's what you get with a Chinese bike feeling like I just threw my money out the window I knew I should have bought a name brand.
Old May 5, 2015 | 07:42 AM
  #24
MPDano's Avatar
My Joyner buggy had the same issue. Threw lots of new parts to it. Mine was a bad rectifier (voltage regulator) and was not jetted correctly (too lean).
What is your location elevation?
BuggyNews Buggy Forum ? View topic - 2006 Joyner 250cc Viper LOW Power??
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
