110cc chinese atv NO SPARK
Old Nov 30, 2011 | 07:51 PM
jackhm's Avatar
Default 110cc chinese atv NO SPARK
hi i have a 110cc chinese atv NO SPARK i took out the sark plug it only sparks rite after i stop cranking help it has a 4 pin cdi
Old Dec 1, 2011 | 12:09 AM
LynnEdwards's Avatar
Electrical Expert
Four pin CDI's are DC powered. Following is the generic procedure for troubleshooting no spark on 4 pin CDI's. In particular pay attention to the measurement on the timing trigger pin (both voltage and resistance). But report back your findings for all the test steps...
To troubleshoot no spark problems on a 4 pin DC powered CDI it makes sense to start in the middle (the CDI), measure as much as we can and branch out from there. For the CDI to do its thing it needs power and ground, and a trigger pulse.
1) Unplug the CDI. Turn the ignition switch on. Set all kill switches to the the "run" position. Use
a meter to measure the DC voltage on the pin labeled "AC ignition power" in the wiring harness to the ground wire on the 20 volt DC scale. You should read battery voltage (12 volts). What do you measure?
2) Leave the CDI unplugged. Use a meter to measure the resistance of the "Ignition Trigger Pulse" pin in the wiring harness to the ground wire on the 2K ohm scale. You should read approximately 150 ohms. What do you measure?
3) Set your meter down to the lowest scale you have for measuring AC volts. 2 volts would be ideal, but some meters don't go that low. In that case use the lowest scale you have. While cranking the engine, measure the voltage on the Ignition Trigger Pulse pin in the wiring harness to the ground pin. You should measure 0.2 to 0.5 volts AC. What do you measure?
4) Now plug the CDI back in. Measure the AC voltage on the Ignition Coil pin to the ground pin using the 200 volt scale. If you have to, use a sewing pin to poke through the wire insulation and then put the meter probe on the sewing pin. But don't hold your fingers on the connection during the next test - there may be high voltage here when the engine is turning. With the ignition on and all kill switches set to the "run" position, crank the starter motor. You should see voltages bouncing around at random values and the meter captures all or part of a spark event. What do you see?
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
DanP24
Aug 12, 2015 11:39 AM
Waddell4436
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
