help with valve adjustment
Old Dec 19, 2011 | 02:03 PM
minihoser's Avatar
Default help with valve adjustment
I have a kazuma 250cc, with a cn250 engine. I set the cylinder tdc, by putting a straw in the spark plug hole.
I lossen the adj nuts and when moving the intake/exhaust setting or dial there is equal/moderate tension when moving it all the way left or right. Am I missing something?
I thought tension would increase as the valve closes and then you back it off a little.
Thanks,
Jason
Old Dec 19, 2011 | 04:05 PM
minihoser's Avatar
got it running perfect. Tried again on the valves and nailed it.
Stuggled with low end problems prior to valve adjustement. Thought it was the carb/jetting issue and it was really a valve problem. Now it runs smooth.
Time to go riding.
Old Dec 19, 2011 | 06:29 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Id guess you had the wrong TDC the first time.. There are 2 on a 4 stroke and you need the one after the exhaust valve closes..
Glad to hear you got it running.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
