voltage regulator or battery?
Old Jan 3, 2012 | 09:23 PM
the_legend_1981's Avatar
Default voltage regulator or battery?
I've cleaned the carb 3 times and its definitely clean now...Problem is that it runs for awhile and then dies. 10-15 minutes. I'm running it with a dead battery and jumping it and I'm hoping this is the problem. Otherwise, could it be the voltage regulator or water in the fuel or something I could be missing? thank you. It is this model from 2007 http://www.extrememotorsales.com/mini50.htm
Old Jan 4, 2012 | 10:46 PM
LynnEdwards's Avatar
Electrical Expert
If your CDI is DC powered, and your charging system isn't working, and your battery goes dead while riding, the quad will falter and die. If your CDI is AC powered the dead battery has nothing to do with the engine shutting off.
Do you have a 6 pin CDI? This would have two connectors - a 2 pin and a 4 pin. Some of those CDIs (but not all) are DC powered. 5 Pin CDIs are always AC powered.
You could always get some duct tape and alligator clips and wire a meter to the battery while you're riding. That way you could see if drooping battery voltage always correlates exactly with the engine quitting. Another idea would be to jump the quad to get it running, then turn on the headlights. If that kills the quad engine then it's a pretty good indicator that battery voltage is involved.
Old Jan 6, 2012 | 05:05 PM
irishdude's Avatar
ya or once started you could totally disconnect a battery termanal that would kill the engine if itd a dc cdi
Old Jan 6, 2012 | 11:54 PM
Electrical Expert
Yes, that is completely correct. And it is *so* much simpler than my suggestions. Good point IrishDude .
Old Jan 7, 2012 | 11:21 AM
irishdude's Avatar
just glad i could be helpful, and to an expert too!!
Old Jan 7, 2012 | 04:23 PM
frederick's Avatar
Make sure the gas cap vent is working. If it is plugged, it will create a vacuum and stop the fuel flow in just about that amount of time ....
FJB
skinnyr6
Aug 25, 2023 02:18 AM
Bulgin88
Aug 1, 2015 06:39 PM
DeFox500
Jul 26, 2015 06:32 PM
Schneider
Jul 24, 2015 05:05 PM
200es
Jul 19, 2015 04:50 PM
